Browse Forums Building A New House Re: Using Project Builder but doing my floors 5Apr 13, 2014 6:12 pm pongie Also check if your flooring require any expansion gap and if they do make sure your skirting is thicker. We just realized our standard skirting of 10mm thick is too thin to cover the 10mm expansion gap requires for bamboo flooring. So our only option is to replace the skirting (which may affect the architraves if there were the same thickness) or have beading and scotia. This is a good point, I will have to check with the builder about the default skirting thickness, though if 10mm is the minimum I am absolutely sure it will be 10mm They won't save an effort to charge for any thing they can. I had a look at your blog and the building seems great! congratulation 0 2020 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27360 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18300 |
