Browse Forums Building A New House 1 Apr 07, 2014 8:52 pm So we just went to our electrical meeting and was figuring out how many lights to use in each individual areas. Intending to go with LED downlights for most of the house, something like the Dormus 13W Deco. Now how does one effectively determine how much light is needed? Re: Electrical Meeting & How much lighting 2Apr 07, 2014 9:28 pm We were really guided by our builder on that one -i think the use of the room is a big factor ie kitchen has heaps ie 9 and living rooms only 4. I have had somewhere though some indications on how many lights for however many square footage - there is a separate thread here on lighting also! My build thread: viewtopic.php?f=31&t=70636&p=1161767#p1161767 Re: Electrical Meeting & How much lighting 3Apr 08, 2014 11:45 am This may not be quite what you are looking for but, according to this website: http://www.build.com.au/bca-lighting-restrictions the BCA regulates how much lighting you are allowed to have?? and I quote: How many watts per square metre (W/sqm) under BCA guidelines? The main thing you need to be aware of is that as of May 2011, you are only allowed: 5 watts per square metre (5W/sqm) of lighting indoors 4 watts per square metre (4W/sqm) of lighting in outdoor areas (including verandahs) 3 watts per square metre (3W/sqm) of lighting in garages It has come as a surprise to me but presumably your builder will know. Re: Electrical Meeting & How much lighting 4Apr 08, 2014 1:27 pm But builder just refer us to the electrical guys which is home consulting. Seems like we can have as much as we like, as long as we supply the fittings, they just charge for installation.. Sent from my HTC Re: Electrical Meeting & How much lighting 5Apr 08, 2014 6:51 pm Are you owner building? I assume you are considering you are supplying your own lighting? In that case you could ask the suppliers as Im sure it would depend what type of lights you are using as to how much space they light My build thread: viewtopic.php?f=31&t=70636&p=1161767#p1161767 Re: Electrical Meeting & How much lighting 6Apr 08, 2014 9:05 pm lila rose Are you owner building? I assume you are considering you are supplying your own lighting? In that case you could ask the suppliers as Im sure it would depend what type of lights you are using as to how much space they light Nah we're going with plantation, just got plans approved and need to get this electrical signed off. Just need to make up my mind about how much lights. I went to beacon lighting but the sales doesn't seem to be that informative. I went online and it seems i found the domus 13w downlight seems to be one of the more efficient ones at a good price: http://www.ledbenchmark.com/display.php ... Tilt+White I think i might just have to buy one to try it out. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8770 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8551 |
