Browse Forums Building A New House 1 Apr 01, 2014 9:18 am Looking at roofing options for new house build and looking at Colourbond vs Monier Horizon Flat Roof Tiles Looks like we have to pay around $3500 extra over colourbond for these style roof tiles, has anyone used them and what are your thoughts? Apparently part of the increase is due to Sarking being installed. Have others found they are more expensive than normal roof tiles and than colourbond? Also they will be on a 26 degree pitch roof which from what i have read seems fine for a tiled roof with regards to water run off.. http://www.monier.com.au/Tiles/Show_Horizon.aspx http://www.betterthansheets.com.au - Why use sheets for curtains in your brand new home use Better Than Sheets Temporary Paper blinds instead! Re: Flat Roof Tiles - Monier Horizon 2Apr 01, 2014 9:37 am We are building with Simonds in SA and they had just changed suppliers from Boral to Monier. Normally in SA, with most of the builders you can choose between colourbond and tiles (not shingle style) for about the same price. We were always going to go for colourbond, but with Simonds it was an extra $3,200. (We have a 25 degree roof pitch). The Monier Horizon tiles were only $1,000 above standard inclusions, so we went that route after seeing some examples on homes and really liking the look. We've gone with the Sambucca coloured ones. Yet to see how they go on this place, but we actually can't imagine not going the shingle style tiles now! I've lived with both types of roof, and really can't distinguish a difference - people will always give their reasons why one is better than the other, but I think they have their own + and - and come up even in the end. I'd just go with what you like the look of the most and if you are happy to pay for the look, why not? They do look fantastic. Thread: viewtopic.php?f=31&t=66299 Slab: 16/6/14 Frame: 4/7/14 Roof: 22/7/14 Lock Up: 20/8/14 Fixing: 26/8/14 PCI: 9/10/14 Handover: 20/10/14 Re: Flat Roof Tiles - Monier Horizon 3Apr 01, 2014 10:11 am Hi there, I really wanted these tiles because I think they are very stylish, but I was quoted an extra $5000 at prestart to upgrade for a single storey 25 degree pitch roof. I found that ridiculous, so I just stuck with the Monier Hacienda Profile, which was the standard selection. I'm building in WA with Redink if that helps. Re: Flat Roof Tiles - Monier Horizon 4Apr 01, 2014 11:33 am That question sounds familiar ...
I can't answer for a comparo between those specific tiles & Colourbond; however, those tiles WERE extra over the Monier ones included with our place. Ours is one of the builders where the Colourbond option costs more than the tiles; but it seems many other builders will charge more for the tiles we have than for Colourbond. IMHO if you can save money by not having those tiles, and you don't particularly care either way; then save the money. Colourbond is still a bit noisier in heavy rain; but a lot of people like that. Colourbond is better in those twice-in-a-lifetime hailstorms. In terms of longevity & insulative properties, tiles & Colourbond are much the same by the time they're installed properly with whatever blankets etc (unless you're on an absolute beachfront or similar - then corrosion is an issue with Colourbond, allegedly). That cost over Colourbond doesn't sound like they're ripping you off, though, that's about the amount extra I'd have expected if we'd upgraded from the standard tiles to a fancier range. The house being built behind ours has the flat tiles, and I quite like the look of them; I can take a photo if you like, but you can probably grab heaps of photos from all over the 'net. I just had a thought; check how the Colourbond is being installed, before going with it. If they're claiming the extra cost is sarking, then shouldn't Colourbond be installed with a similar layer of some sort of anti-moisture blanket ... Anticon, or some-such? Maybe check around this site to see if that's correct, but I'm sure I've heard people talking about this "Anticon" stuff, and it seems to install in the same place as you'd fit sarking when fitting tiles. Re: Flat Roof Tiles - Monier Horizon 5Apr 01, 2014 11:38 am I more want them for the 'look' i'm a big fan of the 'pavilion' / 'Asian' style like the picture above and want to replicate a similar style look with the exposed eaves and rendered brick finish, it seems that most if not all houses in this style are using a flat shingle style tile rather than a colourbond, I also notice that where i live in brisbane the more affluent suburbs tend to use these style of tiles rather than colourbond (im talking $1m+ properties) http://www.betterthansheets.com.au - Why use sheets for curtains in your brand new home use Better Than Sheets Temporary Paper blinds instead! Re: Flat Roof Tiles - Monier Horizon 6Apr 01, 2014 11:41 am Note my comment at the end of the above (re. checking that under-Colourbond blanket stuff) ... but also, it sounds like maybe you would like a photo of the house behind ours? I'm about 80% sure it's not rendered, and the roof tiles are a very dark colour (probably that charcoal-ey colour in the photo above). It's in a very "suburban" suburb, not surrounded by fancy houses or anything. As you say it's all about fashion & style, what you like ... and I guess if you're worried about resale, what you think more people will like. I'd be fairly confident in saying that in Sydney, the highest volume project-builders are using tiles; but they're not the flat ones, the flat ones are definitely more exxy. I personally think they look great; but we've made a point of just going with "stock standard" on everything to do with appearance. Re: Flat Roof Tiles - Monier Horizon 7Apr 01, 2014 11:53 am Forg Note my comment at the end of the above (re. checking that under-Colourbond blanket stuff) ... but also, it sounds like maybe you would like a photo of the house behind ours? I'm about 80% sure it's not rendered, and the roof tiles are a very dark colour (probably that charcoal-ey colour in the photo above). It's in a very "suburban" suburb, not surrounded by fancy houses or anything. As you say it's all about fashion & style, what you like ... and I guess if you're worried about resale, what you think more people will like. I'd be fairly confident in saying that in Sydney, the highest volume project-builders are using tiles; but they're not the flat ones, the flat ones are definitely more exxy. I personally think they look great; but we've made a point of just going with "stock standard" on everything to do with appearance. would you mind snapping a photo of the house behind you so i can have a look at all? http://www.betterthansheets.com.au - Why use sheets for curtains in your brand new home use Better Than Sheets Temporary Paper blinds instead! Re: Flat Roof Tiles - Monier Horizon 8Apr 01, 2014 5:07 pm suspct Would you mind snapping a photo of the house behind you so i can have a look at all? This sounds like a good excuse to leave work ... on my way! It'll only be a camera-'phone shot, but should be good enough ... will attempt to remember to upload tomorrow. Re: Flat Roof Tiles - Monier Horizon 9Apr 02, 2014 9:37 am OK here we go ... also finally got to have a chat with the "back door" neighbours too, they rented the old place out as soon as they bought it, and when they moved into the new house we'd already moved out. In person they're a dark grey with a tinge maybe of green to them; pretty close to the colours he's used on the fence out front. Apologies for the quality, the 'phone wasn't quite handling the glare from above. http://i87.photobucket.com/albums/k124/originalForg/Flat_Tiles_zps5575ceb4.jpg Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2783 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13904 |
