Hi just looking at the papers and i can't seem to work it out, what would be the best way for the house to sit? Along the front is the river and views, anyone got ideas for getting the best of of the views? Not done anything yet, still looking for builders and plans.
Cheers Lorri
Placement of house?
Cheers Lorri
Hi just looking at the papers and i can't seem to work it out, what would be the best way for the house to sit? Along the front is the river and views, anyone got ideas for getting the best of of the views? Not done anything yet, still looking for builders and pland.
Cheers Lorri
Cheers Lorri
You might want to be a bit more descriptive, that's very little to go on.
It really depends on where you are, your aspect ie: north, south, east or west as to the best placement..
You might need to look to see from your documents where if any connections are available. ie: electricity, water, etc.. Also which part of your block you are allowed to build your house. ie: building envelope. You better find these out before you look at where you want your house to face. The more you find out the better, this will help you more on budgeting.
Your house will need to be above this, the higher the better.
I worked out how to copy a g earth, if you look in the top right hand corner you can see the way north is pointing. Excuse my drawing of the plot but it give an idea of where it is.
We would like a house that has some outdoor areas to sit in to enjoy the sunshine, , no pool , and I don't have any idea where to put the house re a building envelope, nothing on the papers we got say anything.
Cheers
Usually the shire or developer will have a diagram of where the building envelope is.
North orientation to enjoy the sunshine is the best, so if you can choose a plan that maximises the views and has north facing living areas you are half way there... where will the access road be?
What a beautiful spot
The land was subdivided my 5 acres cut off a big block and another 5 acres of the other side of the big block, not sure if it was done at the same time or not. The owner has the bigger middle block still.
Cheers Lorri
Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow…
10/09/2023
1
Move your linen into laundry and access laundry from your present linen space
2/05/2023
1
You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would…
