Browse Forums Building Standards; Getting It Right! Re: Protecting your Slab 491Jun 20, 2015 9:23 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Protecting your Slab 497Mar 05, 2019 10:40 am My house is nearing completion and I am arranging concreting and drainage all the the way around the perimeter. The area below in red will be concreted and drained. Ideally I would like to have lawn right up to the alfresco with subsurface drainage, without a concrete apron around the alfresco as well . Is this a bad idea or should I just concrete the green area (1m wide) as well?? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Protecting your Slab 498Mar 05, 2019 11:21 am brokenstick My house is nearing completion and I am arranging concreting and drainage all the the way around the perimeter. The area below in red will be concreted and drained. Ideally I would like to have lawn right up to the alfresco with subsurface drainage, without a concrete apron around the alfresco as well . Is this a bad idea or should I just concrete the green area (1m wide) as well?? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Protecting your Slab 499Mar 19, 2019 6:49 pm sweetswisssteel brokenstick My house is nearing completion and I am arranging concreting and drainage all the the way around the perimeter. The area below in red will be concreted and drained. Ideally I would like to have lawn right up to the alfresco with subsurface drainage, without a concrete apron around the alfresco as well . Is this a bad idea or should I just concrete the green area (1m wide) as well?? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is that correct? Only 25mm fall. Some say it's 75mm fall. Hmmm Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16159 4 6201 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5160 |
