Browse Forums Building A New House 1 Mar 16, 2014 8:52 pm This might be a stupid question but no one from mcdonald jones can answer. My question is with the dux continuous hot water system, when installed is it recess into the bricks or is that an extra. All the display homes that have it it is shown on outside of bricks not recess. All mcdonald jones homes around my area have that system recess so can someone help me out if they know if it is a standard feature. Re: dux continuous hot wat system 2Mar 17, 2014 6:19 am Can't say for certain about McDonald Jones, but from experience all the builders I talked to stated that the recess would cost extra as it isn't standard. Maybe all those people paid the extra to have it recessed so it didn't stick out of the wall, or that was included in a particular upgrade package? Re: dux continuous hot wat system 3Mar 17, 2014 12:44 pm we will have dux system installed and it will be just outside on the wall First house - Statesman Greenock (modified) https://forum.homeone.com.au/viewtopic.php?f=31&t=66876 Second house - Fairmont Grand Design (modified) https://forum.homeone.com.au/viewtopic.php?f=31&t=100789 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12195 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12635 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20197 |
