Browse Forums Building A New House 1 Jan 29, 2014 7:22 pm Here are some useful links if you want to learn more about slab design CSIRO: Foundation Maintenance and Footing Performance http://www.bostongrp.com.au/documents/e ... 0Perfo.pdf CCAA: Guide to Residential Floors http://www.concrete.net.au/publications ... %20Web.pdf AS2870 http://www.ab.deakin.edu.au/online/vgal ... F/2870.pdf Re: Information on Slab Design 2Jan 29, 2014 8:00 pm I thought my slab was going to be waffle pod - but then they went for standard. I learned so much about waffle pod .... and was a tad disappointed. Some great myths though ... Re: Information on Slab Design 3Feb 02, 2014 12:58 pm Hi akapacker, This is very useful information, particularly the AS document! I'm just a little worried for you that there might be copyright issues here with that last one. But, while we can, we'll have a good read! I was particularly interested to see that the Australian Standard says: 5.5.3 (a) Surface drainage of allotments for reactive sites for both footings and slabs shall be considered in the design of the footing system..." I doubt this happens very often. Re: Information on Slab Design 4Feb 02, 2014 4:36 pm I am not a structural engineer so it would not be within my expertise to comment on slab design however commenting on whether builder is following documented engineering design and specification and or AS 2870 is. Over the last decade I have documented in my reports numerous instances where builder just has not followed approved drawings. Builders flood foundations of homes on highly reactive sites or mess up surface drainage then when home is damaged and cracks appear then they attempt to pass it off as "normal and natural shrinkage" or blame the owner. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Information on Slab Design 5Feb 02, 2014 5:05 pm Hi Building-expert, Where does Standard 2870 "stand" with relation to the BCA? In part 3.1- Site preparation of the BCa there is an explanatory note which says: "1. The BCA does not require the installation of drainage systems." ????!!!! What does this mean? Re: Information on Slab Design 6Feb 03, 2014 6:24 am Hi Liliana As 2870 and AS 3500 Plumbing and drainage are adopted in BCA by reference. In order of hierarchy BCA is above Australian standards but in many cases it simply defers to them. Even though BCA does not require drainage, local authorities do, so you have legal point of discharge from the council which requires that drainage is directed to it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog 0 4982 We are at the stage on our build in Kilcoy, Queensland where we need to get our fencing installed but we cant get any contact details for our neighbours to give them… 0 6158 Although I am a big opponent of using waffle pod slabs over H2/P soils under any circumstances, in your case I would certainly opt in to keep piers under central… 1 2426 |
