Browse Forums Building A New House 1 Jan 28, 2014 2:30 pm Hi, I'm in victoria and building the fortitude 37 with metricon. can anyone advice on possible contractors that do cabinetry and wardrobes? I didn't want to go with metricon on this as they were charging extremely high for it. Any advice would be appreciated. thank you! Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3065 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4895 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 |
