Browse Forums Building A New House 1 Jan 24, 2014 1:55 pm Hi, Can anyone tell me what building code the builders must adhere to here in WA and does anyone know where I can get a copy of it? I want to do some research on the slab and foundations, I'm not happy with the way the builders are doing them but I need to check what the code specifies first. Thanks My build: viewtopic.php?f=31&t=68002 Re: Building Code Help Please 2Jan 24, 2014 2:01 pm Everything is now covered under the National Construction Code (NCC) used to be known as the BCA. Not sure where you are in WA, make sure you look under the correct 'terrain category'. Re: Building Code Help Please 3Jan 24, 2014 2:04 pm They use the Building Code of Australia (BCA) volume 2, also known as the national construction code. I don't think there are any specific WA variations to it. If you PM your email I may be able to help with some info... Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16566 |
