Hi
I hope I explain myself well
With my soffit's, I noticed that there are long holes/gaps on the boards. What is this for? Is it for ventilation? It is something I never noticed on houses until now. Is it a common thing to have?
Thank you!
Browse Forums Building A New House 1 Jan 24, 2014 12:14 pm Hi I hope I explain myself well With my soffit's, I noticed that there are long holes/gaps on the boards. What is this for? Is it for ventilation? It is something I never noticed on houses until now. Is it a common thing to have? Thank you! Re: Soffit question 2Jan 24, 2014 2:43 pm Yes ventilation. Whirlybirds suck the hot air out from up the top hopefully to be replaced by cooler air from outside via these vents. At least that's my understanding! Build thread: viewtopic.php?f=31&t=65085 Re: Soffit question 3Jan 24, 2014 2:48 pm Thank you so much for answering my question. That makes sense. Re: Soffit question 4Jan 24, 2014 3:49 pm If you don't have whirly birds yet, check out the solar powered ventilators that are now available, as they work so much better at drawing the air out of the roof than the whirlybirds do. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . thank you! do we need to get this or our builder before we commence new build on the block? 2 10261 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9942 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6137 |
