Browse Forums Building A New House 1 Jan 23, 2014 10:53 am We've just discovered a large rock on our block that wasn't removed initally. When the builders cut away, they've created a slight retaining wall, as the dirt has then fallen away, the rock has emerged. Should this be the builders responsibility to move or ours? Re: Large rock on the block 2Jan 23, 2014 11:17 am Was there an agreement to remove it originally? Is it in a spot that is detrimental to the build? To be honest if no to these then probably not a builder issue. Re: Large rock on the block 3Jan 23, 2014 11:26 am Also - can you incorporate it into the garden design. Getting big rocks/boulders afterwards is quite hard. And they can be quite a feature. Re: Large rock on the block 4Jan 23, 2014 12:16 pm Its not in a great spot, we already have to deal with an ugly easement on our block (sewerage access and storm water access) which is right next to the rock, its partially along the fence line too which will make fencing difficult. I don't know the extent of the rock until I go back on the weekend with some tools. 4 4499 Hi all, I have been looking at land in South Australia, that is on a slope however most of the core excavation is complete, with a flat area to place a house. The agent… 0 1413 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6633 |
