Browse Forums Building A New House 1 Jan 22, 2014 9:01 am Hi all, Does anyone have any tips on what a stormwater site plan should look like? I am building a shed (a house eventually) and my surveyor says he wants a stormwater plan. This is a rural property, so no existing drainage. he is away at the moment, so i can't ask him what he requires. I am thinking of a plan showing the direction of the water flow and catchment into a rainwater tank. Is that all that is required do you think? Re: Site plans for stormwater drainage 2Jan 22, 2014 10:46 am You also need to think about where any overflow from the tank will go. Maybe to a watercourse or a soakwell? The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Site plans for stormwater drainage 3Jan 22, 2014 2:50 pm Thanks, Yes - I had thought about that but I have no clues how the plans should look. I was just going to draw it out on graph paper, showing the slope, gradient, levelled off area etc. Do I also show downpipe locations and the tank? I can just draw in a soakaway for the tank overflow. Would that be adequate do you think? Re: Site plans for stormwater drainage 4Jan 22, 2014 7:47 pm I take it that you will not be on mains water or connected to stormwater. Is that correct? Are you required to also have a fire fighting reserve storage capacity? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Site plans for stormwater drainage 6Jan 26, 2014 10:53 pm You might have to wait until he gets back and ask him. You could also ask the council. The last I heard, sheds were not regulated for stormwater drainage but I can check to see if this has changed. Just give him a broken line sketch showing the flow path from the shed to the tank. If it's insufficient, he will let you know. I can't imagine him wanting trenching depths and details, IO locations (not mandated for water tank wet systems in Victoria at any rate) etc. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4859 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7932 |
