Browse Forums Building A New House 1 May 16, 2008 1:31 am Ok so we finally have our first inspection booked for next wednesday. So help me what am I looking for, what should I check and how much time should it take? The whole build has been pretty seamless, no issues at all, it looks pretty good so far. Took 6 months from the pad going down. The brickwork is flawless, the wet areas and kitchen look great. I know of a few little things I've noticed along the way like holes in the plaster where they had to punch through for power points after the plasterer just went over them, or a tradie has bumped a wall, but I'm expecting those to be fixed by now and they're not really concerning issues. If you read my thread about the kitchen bench, I saw it today after the flooring went in and it is already blending in a little more.
It's a 4x2 double brick and colourbond, with double garage and solar hot water. I asked my Dad if he wanted to come too, he's a self taught carpenter/handyman/jackofalltrades, and has built a house on his own in the past so his eye should be useful. If there are going to be problems, what are they usually? ta, Em Re: First inspection 2May 16, 2008 5:59 am Hi,
Our inspection took about 2 hours. We started from one end and systematically went through all rooms - starting from the roof, down to the floor. Check windows open and shut, doors open and shut, taps don't leak (and work), shower screens for scratches, cracks in basins, scratches on windows, benchtops - everything! You will probably find that any issues will be pretty superficial - just be critical and tell them about anything you see. All the best! Ray. Second Time 'Round i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98695 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5351 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6531 |
