Browse Forums Building A New House 1 Jan 21, 2014 12:23 pm http://i125.photobucket.com/albums/p45/pintoo022002/Plan-1_zpsdacda44e.jpg Hi everyone, We are in the process of building our first home. I have been looking into this website for months and have gained valuable info . I just got the 1st draft from our builder. Because we have no experience with house plans, I could not resist myself from posting it here. It will be very helpful if you guys have a look and suggest for any modification. Would you buy a house in future if the floor plan is like this? Thanks Re: Home plan advice 2Jan 21, 2014 12:54 pm Some points I've thought of: - the WIR in bed 1 should at least have L shaped shelves to make the most of space. - the pantry door opens really awkwardly into the middle of the kitchen. That will drive you nuts I think. Also there is that awkward space in the pantry where no shelves fit - what is that for? Is that the fridge recess to the left of the pantry there? - I would like wider doors to the alfresco - seems a shame to have only a fairly narrow double door slider there - I'd make sure the front door has glass inserts or sidelights otherwise the entry may be quite a dark area Which way is north? Build thread: viewtopic.php?f=31&t=65085 Re: Home plan advice 3Jan 21, 2014 1:19 pm The robe on Bed 3, could you move the robes in beds 3 and 4 so they are on adjoining walls? Just think the jut out part may be a little odd. You will want a door on the audio visual Agree with Emy on your kitchen/pantry layout. You have wasted space to the left of the pantry there, I am sure with a bit of fiddling you could make the most of it. Consider sound insulation between the laundry and Guest, and if you move the robe, the WC and bed 4 Just before the laundry is a small alcove, will that be a broom closet? Re: Home plan advice 4Jan 21, 2014 1:35 pm I would consider some doors for the theatre room, maybe double doors? Just because the noise from the theatre room will be wuite loud in the living area if there is no way of closing it off. I agree with the above point to make the WIR in Bed 1 an l shape, make the most of robe space! Could you move the robe for Bed 4 to the back of the house like Bed 3 so it isn't taking up space inside the room, then the two robes will even out the back wall so it isn't such a small bit sticking out. Does the linen/store room have shelving? And the cupboard in the garage? (I like the cupboard there!) It might not be something you want but I would make the shower in the ensuite go wall to wall so it was bigger (only if the floor space wouldn't be too small by doing so). I have found having a large shower to be wonderful You can add overheads above the fridge recess? Also make the pantry shelving into an L shape on the right side for more storage, even if it is just a narrow shelve. Door to the study? Otherwise noise will carry from theatre and no study will be done haha Nice plan though Good size rooms! Re: Home plan advice 5Jan 21, 2014 2:48 pm Thanks Emy, Tina and Felicity for your inputs. So overall its not a bad plan? I have also been thinking about the points you have raised. Something has to be done with the WIP. The space near it is the freeze space. -robe in bed 4 outside like bed 3. -will have a look if there would be any space in the en suite if the bath goes wall to wall. -Double door to AV room/single to study. -Bigger sliding door to alfresco -L shaped WIR in bed 1 Have been thinking about extending the garage to the fence so that we won't have to put 2 side gates. Currently the length is about 6.5m. Do you think it will look odd if we extend it to 7.5m? We are also thinking of raising the ceiling in the entry to 31c and putting a double door (1.6m) to the entry. Any thoughts? North is towards 10-15 degree N. (I guess...he he) Thanks Re: Home plan advice 6Jan 21, 2014 6:02 pm The alcove next to laundry I would either build in a small linen / broom cupboard or extend the laundry all the way to the hallway inline with the bathroom otherwise it may become a bit of wasted space. My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Home plan advice 7Jan 21, 2014 6:09 pm Also you could maybe 'square off' the pantry and have it cut into the AV room it might help make better use of the space in the pantry and should have too much of an impact on the AV room especially if you add doors that swing into the room My Baldivis Build: https://forum.homeone.com.au/viewtopic.php?f=31&t=67953 Re: Home plan advice 8Jan 21, 2014 6:23 pm Thanks Lethe for pointing out the Laundry. I have been thinking the same and just can't understand why that space is left like that. I will discuss with the builder about that. I thought of extending the laundry, but again feel that none needs so big a laundry. Any other ideas for making use of that space? Re: Home plan advice 9Jan 21, 2014 8:31 pm Personally I'd swap the toilet and shower in the ensuite - and make the shower the full length of that wall, so instead of the approx 900x900mm it is now, make it 900x1800ish or whatever it'd work out.
Also, I'd bring the toilet next to the main bathroom so its door is right back to where the doorways to bed 4/bath are and give yourself that extra 150mm or so in the toilet, and perhaps have a small sink in there to wash hands before putting potentially 'poopy hands' on the door handle to get out... And also better if someone is in the main bathroom. The wardrobe space in bed 3 is awkward. I'd have the robes for bed 3/4 on the shared wall maybe. Re: Home plan advice 12Jan 21, 2014 10:19 pm you can put a door on the l'dry too i think having the pantry like this will give you more space that you can use Re: Home plan advice 13Jan 21, 2014 10:30 pm Re: Home plan advice 14Jan 21, 2014 11:22 pm Seano, both the points noted and thanks a bucket for pointing out. I didn't see them earlier. Both of them are definitely going into the house . Thanks a lot 2-cupcakes-pls for the detailed plans. I will think about the changes tonight . Re: Home plan advice 15Jan 21, 2014 11:31 pm BTW I was wondering how much it costs (roughly) for flooring and painting outside builder except the wet areas (lets say 270 sq m house, carpets for rooms and timber elsewhere). The quotes I got from the builder feels astronomical to me Re: Home plan advice 16Jan 22, 2014 1:55 am Re: Home plan advice 18Jan 22, 2014 5:01 pm I extended our garage out to the fenceline so we only have the one side gate, plus it gave us lots more storage space in the garage. The space that would have been down the side was hardly big enough to be more than a narrow walk way so would have been a waste! Much better to utilise sotrage and work bench space for us. It does involve extra costs for having the house on the fence line but you could build it up to the fence line (so the fence would be right against it) to avoid that is you wanted? Also doesn't look bad from the front, hardly noticeable! Re: Home plan advice 19Jan 28, 2014 9:34 pm Thanks felicity, I talked to the builder and he says they would charge an extra 3k for special material batt(?) if we extend the garage to the fence (on top of regular extension cost). So we are thinking of giving up the idea. The builder is charging 1.3k for front render paint which I thought would be standard. Anybody has any idea about this? As we are thinking of going for internal painting outside, is it a good idea to do the front render outside as well? Another question: builder says site cost will be 16.5k ('A' class soil with S class footing, no inclination). Is it the standard site cost price? Sorry for asking too many questions Re: Home plan advice 20Jan 29, 2014 8:29 am our is class A site works with the soakwells is $7,000 I don't know about the footing Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17900 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45817 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17278 |
