Browse Forums Building A New House Re: Dirty kitchen in garage 22Jan 14, 2014 3:34 pm Matt1 I'm getting a tap, gas point and drain installed in my garage. Not for cooking though, for homebrew. which builder? would you mind asking cost for all three points in garage. Re: Dirty kitchen in garage 23Jan 15, 2014 12:59 pm Wisdom. $890 for capped off hot/cold water point + drainage point. $275 for the gas point. Re: Dirty kitchen in garage 24Jan 15, 2014 1:42 pm Quote: Hey bash, are you sure that it's illegal in Vic to vent range hoods into the roof cavity in Victoria? In NSW it has been illegal for at least twelve years so I'd expect the same for Victoria ( that's how a lot of house fires used to start until they made it illegal ). Stewie Re: Dirty kitchen in garage 25Jan 15, 2014 8:47 pm Matt1 Wisdom. $890 for capped off hot/cold water point + drainage point. $275 for the gas point. Thanks Matt, this will help us in tender appointment. It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17198 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
