Browse Forums Building A New House 1 May 14, 2008 1:27 am Hi everyone,
cant believe i didn't find this site until after we signed up with our builder, have found some great advice and ideas, so thank you all so much. anyway, my question is .... if anyone has built with Homebuyers Centre here in Perth, did you have to pay extra to get the roof pitch up to 25 degrees? our estate requires a roof pitch of 25 degrees or more (not uncommon at the moment) and when we went in to sign up there was an extra charge for raising it up, apparently it only comes at 20 degrees as standard. its not a massive charge but th money would definitely be better in my pocket than the builders. i have checked the brochures etc and no mention of roof pitch anywhere. any comments or experiences would be helpful, thank you. Re: roof pitch costs extra??? 2May 14, 2008 9:46 am In Melbourne where we are building, my builder has quoted $1200 to increase roof pitch from standard 22.5 degree to 25 degree....
If your estate requires a 25 degree roof pitch, i guess you dont have much choice... Re: roof pitch costs extra??? 4May 14, 2008 1:10 pm This is an interesting topic.
I never even thought about our roof pitch But when I just went to check our specifications, 25 deg is already the standard so our house is being built to that anyway. (colourbond roof which was also standard) I am not sure if our area has any rules on this. Re: roof pitch costs extra??? 5May 14, 2008 7:40 pm higher pitch means a little more timber in the trusses and a little extra length on the Colorbond sheets/ extra tiles Re: roof pitch costs extra??? 6May 14, 2008 10:37 pm we are building with PD in Melbourne and had to increase our roof pitch to 25 due to estate covenant. The cost was just over $700 - we thought it was cheap! Re: roof pitch costs extra??? 7May 14, 2008 11:26 pm 5inmytribe Hi everyone, cant believe i didn't find this site until after we signed up with our builder, have found some great advice and ideas, so thank you all so much. anyway, my question is .... if anyone has built with Homebuyers Centre here in Perth, did you have to pay extra to get the roof pitch up to 25 degrees? our estate requires a roof pitch of 25 degrees or more (not uncommon at the moment) and when we went in to sign up there was an extra charge for raising it up, apparently it only comes at 20 degrees as standard. its not a massive charge but th money would definitely be better in my pocket than the builders. i have checked the brochures etc and no mention of roof pitch anywhere. any comments or experiences would be helpful, thank you. Hi, where abouts in Perth are you building? Re: roof pitch costs extra??? 9May 14, 2008 11:47 pm thanks for your help/comments everyone, i know we dont really have much choice, i suppose i was just hoping that someone might know whether or not Homebuyers Centre have a standard roof pitch and what it was, just didnt want to get shafted for no reason.
i understand there are more materials etc, just wasn't made aware of it until we were signing up, no mention of it when we were talking about things we needed to do to get th house approved by the developer etc. lloydmav - eastern suburbs cheers all Re: roof pitch costs extra??? 10May 15, 2008 11:44 am We wanted a 27 deg. roof pitch,but the encumbrancer made us lower it to 22.5 ,because it,s a 2 storey it would have made our house too high We were a bit annoyed as we love the higher roof pitches.
If we,d had the 27 deg. pitch it would have reduced our eaves from 450mm to 350mm. Anyway it,s saved us nearly $1000,but I would have still preferred the higher pitch Cheers Mel Building on 9 acres Re: roof pitch costs extra??? 11May 15, 2008 11:50 am Always go for a higher roof pitch if possible, and even better, rake your ceilings. The extra head room is priceless (though it does cost!). Standard ceiling heights are just too low. The most beautiful doors and furniture in the World Re: roof pitch costs extra??? 12May 15, 2008 12:29 pm Quote: Always go for a higher roof pitch if possible, and even better, rake your ceilings. The extra head room is priceless (though it does cost!). Standard ceiling heights are just too low. Standard ceiling height = 2440mm?? Re: roof pitch costs extra??? 13May 15, 2008 1:11 pm 2440mm is OK, but on a 2nd level they tend to drop it to less especially if you are extending on an older home. The most beautiful doors and furniture in the World Re: roof pitch costs extra??? 14May 15, 2008 4:45 pm I just checked my roof pitch, it is 28 degree! What is the really advantage of the high roof pitch? Our ceiling height is 2445mm on both levels. is it standard? Re: roof pitch costs extra??? 15May 15, 2008 5:07 pm Dukekamaya higher pitch means a little more timber in the trusses and a little extra length on the Colorbond sheets/ extra tiles That never even occured to me! My company always builds shallow pitch roofs, I asumed because they are all new arty farty building designed by arty farty architects, now I know why! It's all colourbond too. teach me Re: roof pitch costs extra??? 16May 15, 2008 6:41 pm Quote: Dukekamaya wrote: higher pitch means a little more timber in the trusses and a little extra length on the Colorbond sheets/ extra tiles Quote: That never even occured to me! My company always builds shallow pitch roofs, I asumed because they are all new arty farty building designed by arty farty architects, now I know why! It's all colourbond too. Depending on the area - a higher roof pitch will also mean higher wind resistance -and if that's already on the edge of the limts - it may extra again to strengthen it all to to support the additional windage. Steve Re: roof pitch costs extra??? 17May 15, 2008 7:23 pm rldragon2003 I just checked my roof pitch, it is 28 degree! What is the really advantage of the high roof pitch? Our ceiling height is 2445mm on both levels. is it standard? I was under the impression that 22.5% roof pitch is the "standard" with 450mm wide eaves. Higher pitch roof plusses *Roof less likely to leak as water runs off quicker *More head in ceiling space *Can possibly create a real & usefull actic *Hot air in roof space further away from ceiling (cooler in summer) Higher pitch roof minuses *More expensive due to material costs *More difficult (and possiblly expensive) for trades to work on top of roof *Reduction in eaves width (unless you pay more again) Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: roof pitch costs extra??? 18May 15, 2008 10:23 pm Standard ceiling height is (approx.) 2400mm/8ft or 2700mm/9ft Roof pitch clause 19Jun 15, 2008 3:36 pm I too have signed up with The Homebuyers Centre and ran into the 25° roof pitch issue.
The original house design ( Aussie Alfresco ) was altered for rear access. Land caveats on the Butler lot then required a 25° pitch, costing $1600. The original 21° pitch was saved simply by running eaves across the entire front of the house. In fact, I used most of the $1600 credit to finish off eaves to the entire house. I really wanted a lower profile roof, especially on a coastal, wind prone lot. What an odd little clause! Why don't you call and talk with someone at the town planning in your council? 1 2178 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4191 |
