Browse Forums Building A New House Re: Tiling Query 2May 13, 2008 7:51 pm Quote: Which are the tiled areas of your house (other than wet ares)? None. well,only the front porch, all interior areas are either floating floors or carpets. However, I can't see why you couldn't do this, maybe not with the wet areas, as builder probably has legal requirement to hand over in usable state, but other areas - many people do carpet etc themselves so can't see any difference. At worst you may have to do it after handover but if you already have a quote and tiles selected this could delay moving in by only a few days. Doing it even after you have moved in would be possible but more inconvenient. Presumably you would save money by not paying builder's mark-up. Re: Tiling Query 3May 13, 2008 8:17 pm Archieein,
As we can't do our own tiling for the wet areas, we just let the builder do it but we upgraded our tiles. After handover, we are going to have our entry hallway, dining, kitchen, family and mud room areas tiled. We asked for a quote and it was too much (approx $14k excluding the mud room area) for standard tiles! If we upgrade to the porcelain tiles that we are going to use in wet areas, it would double up the cost! IF we do it after handover, it would be around $12K-$14k only. Still very costly, but cheaper than the builder's quote. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Tiling Query 4May 13, 2008 11:41 pm I guess it depends on your builder. Ours wanted $10k for about 100m2.
We went into the shop that supplies them and we could do the exact same tiles for $6k (supplied and layed). We are still going to spend $10k but we got to choose much nicer tiles from a complete range instead of a "builder's range" IMO if you are in no hurry to move in and you don't mind doing some shopping around then you can save a lot of money on these things. Re: Tiling Query 5May 14, 2008 9:39 am Thanks VJ, Helyn and SouthBris
I will surely talk to some tilers and get a quote and compare it with Builder's quote and then decide. ---------------------------------------------------- VJ, Thanks for your input. Quote: IF we do it after handover, it would be around $12K-$14k only. Still very costly, but cheaper than the builder's quote. So, you imply that after handover you will spend $12k-$14k for porcelain tiles or standard tiles? Re: Tiling Query 6May 14, 2008 5:33 pm Hi, Yes we did consider it briefly.
Basically we originally wanted Slate tiling everywhere except the bedrooms, the builder said they wouldn't do slate but were willing to make a provision in the contract (to cover the cost). It also seemed that they didn't want to do it prior to handover due to risk of damage by tradies etc. In the end after advice from the tiling shop, they said it was hard to find good slate and tilers who can lay it well in our area, so we chose a nice ceramic floor tile instead. The builder is happy to do that, and I don't think the cost is much greater than if it were to be done externally (mainly due to our location, we'd have to pay an hours worth of travel for whoever we got to do it). I figured that the builder had to get a tiler in for the bathrooms etc anyway. We are still doing the carpets after handover, price wise we will probably end up slightly in front I guess. And besides the carpet place said it's not much use choosing the carpets too far in advance as styles and colours tend to change pretty regularly. Re: Tiling Query 7May 14, 2008 8:26 pm Quote: VJ, Thanks for your input. Quote: IF we do it after handover, it would be around $12K-$14k only. Still very costly, but cheaper than the builder's quote. So, you imply that after handover you will spend $12k-$14k for porcelain tiles or standard tiles? Archieein, We will spend $12K - $14k for porcelain tiles after handover, which is the same as the builder's quote but for standard ceramic tiles only. And with that amount, we have chosen an expensive porcelain tiles, which is not even available from our builder's supplier. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! 2 7175 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6680 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7524 |
