Browse Forums Building A New House 1 Dec 11, 2013 1:45 pm Hello I am designing my future home after purchasing a block that will be registered in few months. http://www.flickr.com/photos/103002331@ ... /lightbox/ While its understood that house requirements are personal and vary from person to person. Any opinion is much respected and appreciated, even a small idea might make a big difference! What would you modify in this plan ? Thanks for all Re: What would you modify ? 2Dec 11, 2013 2:05 pm Hey great to see you having a play with designs and layout. Only two things I can really notice; 1 - Storage in upper bedrooms 2 and 3. 2 - Ceiling height - I keep posting this in all threads. If you can afford to do it, put in 2.7m ceilings. Massively opens up even the smallest home. Re: What would you modify ? 3Dec 11, 2013 2:52 pm The downstairs bathroom has an awkward layout Upstairs bathroom- is adding a window possible? Robes in Bed 2 and Bed 3 I assume the door in the Bed 1 ensuite has rotated? Did you want a window at the stairs so you don't need a light on during the day? Re: What would you modify ? 4Dec 11, 2013 8:07 pm No built in robes?? Was this designed by a professional? The footprint of the stair seems small... And there seems to be a lot of wasted space on the upper floor. Build thread: viewtopic.php?f=31&t=65085 Re: What would you modify ? 5Dec 11, 2013 8:55 pm More storage. Also we are renting in a two story and the main bedroom is downstairs and kids bedroom upstairs which if I was building a two storey I would def consider along with good sound insulation between floors Re: What would you modify ? 7Dec 11, 2013 11:01 pm I think the locations of the rooms are ok. However the plan seems to be more a concept than a working plan as I can see that there are far too many things probably not in scale. Also as stated by EmyN, there are quite a bit of waste space. My suggestion would be change the plan into square bubbles of where you want each room to be and ask for professional advise on changing your concept into a plan. Good luck. Re: What would you modify ? 8Dec 12, 2013 12:58 am If you're still conceptualising a floor plan here are some things to consider: Access for moving furniture - especially big units of furniture and up windy stair cases. You might find yourself lifting things through balconies/windows . Tight angles between doorways etc. moving big couches are especially a pain. Design it to make it easy for moving things around. Direction of door openings Consider available wall space when placing doors/windows for your pictures/art/tv/shelves. Window heights - floor to ceiling or half, having some wall underneath can allow for furniture to be placed whereas you will want to keep full height windows clear. Can never have too much storage space. Fit one in where ever practical. Add structural features in to make the house interesting at the same time functional. This is what will make your place special. Enjoy the process! Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8775 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39724 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2463 |
