Browse Forums Building A New House 1 Nov 29, 2013 12:40 pm In the process of purchasing a 10m wide x 30m land and was hoping for some recommendations of builders for narrow lot designs Re: Narrow Lot Designs and Recommended Builders 3Nov 29, 2013 3:54 pm And do you want single or double storey? High end or budget? Cottage (rear loaded) or traditional block? Our house is on a 300m2 block 10x30 but our budget was tight so we have a single storey 3x2. We're in perth so if that's what your looking for I am pretty sure I have seen almost every plan by a project builder that fits on the block Re: Narrow Lot Designs and Recommended Builders 4Nov 29, 2013 7:15 pm Hi and thanks for your responses thus far... site is located in Bedford, Perth. - Looking at single storey with a mid range budget of (~$300k) on a traditional block... Approx 339m2. The only concern I have with single storey is the size allowable and it being too small... site coverage is 50% in Bayswater Shire with an application of 55% allowable in most circumstances. Cheers Re: Narrow Lot Designs and Recommended Builders 5Nov 29, 2013 7:27 pm You can see our plan on my thread our house is at 53% coverage for our block. My favourite house plan for a 10m wide traditional lot at the moment is the Drysdale by Wa housing centre, its on display in harrisdale. There are a few changes I'd make but I think it makes good use of the space and still gives a good kitchen which is lacking in so many of the smaller houses! Is $300 total budget or just for the house? Re: Narrow Lot Designs and Recommended Builders 6Nov 29, 2013 7:31 pm Thanks Fmac, $300k is the budget for the house only...of course I would like to come well under Re: Narrow Lot Designs and Recommended Builders 7Nov 29, 2013 7:37 pm Well I can tell you our house came in a little under $200,000 though we didn't raise the ceilings we do have stone benches throughout, we made the house 1m longer, the kitchen has all pot draws and the builder did all the flooring and blinds. That included site works. Your other option is go to a smaller builder who will do a custom design for you. Will cost more but you'll get something the suits the block and your lifestyle. Some of the designs for 10m wide blocks by some builders I think compromise of living area/kitchen space to try and include everything. Re: Narrow Lot Designs and Recommended Builders 8Nov 29, 2013 7:42 pm The other option is two storey, but there appears to be a lot of waster space for what I want... I simply want a 3x2 with study preferable... My only concern with single storey is that it looks pokey and small. Raising the ceiling is one way around this I guess, maybe a small builder like you say could be the way to go! Re: Narrow Lot Designs and Recommended Builders 9Nov 29, 2013 7:51 pm If you look at 2 storey to save money I have heard good things about BT. For single storey but more custom many people have had good things to say about redink. If your worried about it looking small from the exterior they can do some great things with the facade to give the house more presence Re: Narrow Lot Designs and Recommended Builders 10Nov 29, 2013 8:03 pm BT? Thanks so much for your help BTW... Re: Narrow Lot Designs and Recommended Builders 11Nov 29, 2013 8:11 pm Ben trager The have a concrete slab for second story but use frames for the walls. Makes the build quicker then traditional two storey. It's also meant to be better then the pod system of 101 in regards to noise from upstairs to down. Re: Narrow Lot Designs and Recommended Builders 13Feb 25, 2014 11:27 am Hi tsmith, What do you know about the breakthrough range at APG? Thanks Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4798 Thanks again for this information. If you do hear anything different, would be great to know 4 8324 Your best bet might be to go visit the display homes and walk around in them, and take photos. Get a feel for it in person instead of deciding from the floor plan. There… 1 21462 |
