Browse Forums Building A New House 1 Nov 24, 2013 6:33 pm 1. SECTION6/7 needs WEINESS: witness must not be an applicant or spouse/partner of an applicant and must not be related to the applicant or spouse/partner. So who can be the witness? JP/Policeman? What kind of documents should I present? 2. Two documents of Contract to build: A. a copy of your contract to build, dated and signed by all parties. Submit all the copy of contract which contains over 100 pages or just a few main pages? B a title search showing the applicant as the registered proprietor. Check at https://shop.lpi.nsw.gov.au/wps/portal/ ... cFQGqIqMf/ and found my address is not found, is it because I just got occupancy certificate two week ago? Thanks a lot... Re: A few FHOG questions 2Nov 25, 2013 11:07 am 1. If it's not specified then I believe any adult (someone over the age of 18 years) can witness, as long as they're not a relative as stated. 2. I think you would need to send a full copy of the contract. 3. Did you use a conveyancer/solicitor? They should have a copy of a title search. Otherwise contact your bank (I'm assuming you have a mortgage?) to make sure they have lodged the Transfer of Land. If you have any other questions I suggest you contact the State Revenue Office (or whatever it's called in NSW) directly as they are the ones you are lodging the form with! Re: A few FHOG questions 3Dec 03, 2013 1:54 pm Any one who is 18 years and over and is not related to you can witness your signature. In regards to the contract, it depends on which state where you are buying your property. Also if it is new house or an established house. If it is an established house, you will only need the relevant where both you and vendor signed. If you are buying a block of land and building new house, you will have to provide the building full building contract. Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10465 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4494 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8229 |
