Browse Forums Building A New House 1 Nov 22, 2013 10:45 pm Hello I have been agonising as you do over front doors! I need help! I am considering Jason Benchmark Aluminium and glass doors instead of the traditional wood (a 1200mm pivot was my other choice) Our house has a beach theme with the colours we chose. Dune and Grey pebble render out the front with Pearl white window frames. Are there any downfalls I should consider with Jason double doors? has anyone else done this? I have only seen it on some display homes. But at the time we were looking I didn't really take note of the doors. I may have to have another look through? thanks in advance for your input Re: Need help deciding on front door 2Nov 23, 2013 12:07 pm I'm not sure what doors you're talking about? If you choose a colour that matches the colour of the garage door, I think that would work well. Also take into consideration whether or not you'll eventually get a front door security screen. Re: Need help deciding on front door 3Nov 23, 2013 12:36 pm We've got the Jason Benchmark door in our laundry and it looks great, and a pivot door at the front. I think if you're going for a beachy look then a pivot door for the front would look better as you could stain it to tie in with that theme. I think the glass doors are a bit business looking. Re: Need help deciding on front door 4Nov 25, 2013 6:03 pm I have always wanted a big pivot door but we had trouble with the fire regs as our block is BAL 19. So my next choice was the commercial looking glass doors. I was thinking one big one on a pivot but then that was no good for the regs either. In the end we couldn't get a Corinthian wood and glass pivot but the Hulme doors were rated for the fire resistance we needed. I cannot wait to have a huge door on a pivot!! We considered painting it to match the interior but decided to keep it wood to go with the exterior. So basically I would love either of your choices Re: Need help deciding on front door 5Nov 25, 2013 6:24 pm Thanks for all of your input. I think I have decided to go with the benchmark double door instead of a hume pivot. I have kept my eye on houses on the weekend and saw many benchmark doors. All of them a dark charcoal colour and I'm after a white like the window frames. Personally I would like something slightly wider than a normal width and just one but I think I will just go the double ones Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24800 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2674 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
