Browse Forums Building A New House 1 Nov 21, 2013 12:15 am Hi my builder wants to charge for NBN connection 700. for cat 6 phone and data point. i thought there would be no charge as NBN will connect to the house for free and the isp provider will connect to the internal of the house? can some one please let me know is the builders NBN charge neccessary?????? Re: NBN builder charge???? 2Nov 21, 2013 5:36 am Ours was just over $700 and we had to connect it as it was in our estate's guidelines. 19.03.14 - Land Settlement 15.04.14 - Building Permit 28.04.14 - Earthworks 14.05.14 - Slab Stage 20.05.14 - Frame Stage 11.06.14 - Lock Up Stage 03.07.14 - Fix Stage 15.08.14 - New Home Presentation Re: NBN builder charge???? 3Nov 21, 2013 8:39 am I've wondered this too. Our builder put $500 in the contract but we've received paperwork from TFE electrical saying the min requirement is $995 - I'll be seeking other quotes. Follow my build: https://forum.homeone.com.au/viewtopic.php?f=31&t=63022 19/1 Contract 3/7 Slctns 10/7 Bld Int 23/10 Land Settle 21/11 Slab 14/1 Frame 28/4 Kitchen Re: NBN builder charge???? 4Nov 21, 2013 10:50 am Probably wont affect many - but actually make sure you have NBN in your area. We were going to be charged $600 for an NBN connection which doesn't exist in our area. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: NBN builder charge???? 5Nov 21, 2013 12:51 pm There are two things. NBN connection from outside your house to a point inside your house or garage. That's the free bit (IF you are building in a Greenfields estate). Internal cabling inside your house (sometimes referred to as smart wiring) is optional and that is where the $700 charge is. That seems excessive to me, however, for a single data point (says she who is getting about 15). If you choose not to put in any data points then the only way you will be able to access the internet around your house is wirelessly (and thereby sacrificing the speeds available from NBN), or connected by ethernet cable to your router. My friend was charged $1500 by her developer to 'enable' her to be NBN ready, and as a previous poster pointed out, NBN did not end up coming there. Ripping off the technically challenged if you ask me. Question everything. Don't simply accept a vague amount for something you don't understand. My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25887 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20434 |
