Browse Forums Building A New House Re: Colourbond roof (pictures wanted plz) 6Nov 24, 2013 8:52 am If you're able to - drive around and take photos of houses you like because you'll also see what else works with the roof colour.... eg. certain driveway colours, window frames etc. If you start to see a theme in the photos.... ie you like the same thing over and over... that will make your decisions a lot easier. Eucalypt and ironstone are very different. From a feng shui perspective, eucalypt is the better option..... if you follow feng shui..... but I also think with choosing eucalypt you'll have to be really clever with the other choices. Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8513 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 Yes i guess this is one of the main reason as i checked one post foundation 4 9997 |
