Browse Forums Building A New House 1 Nov 19, 2013 11:21 pm Hi All, anyone has knockdown rebuild with clarendon? We got tender from clarendon and it looks expensive to us. site cost: 40k council and other requirement :13k and another issue on our block is overhead electrical wiring and the allowance for this as below in tender: protection of overhead electrical wiring servicing adjacent property : $3,000 Due to above site constraint ,provide hoarding to scaffolds to comply with occupational Health and safety requirements :$3,000 provisional allowance for de-energizing of the power lines during scaffold install and dismantle ,subject to network operation requirement: $3,000 Above total 9000$ for electrical wiring allowance . Any advise will be appreciate? Re: Anyone knockdown/ rebuild with clarendon 2Jan 04, 2014 10:16 pm Hi, we are doing a knockdown rebuild and have been told by another builder too that there are quite a few additional costs associated with this. So what you've said sounds correct to me based on my limited knowledge. How far into the building process are you? Re: Anyone knockdown/ rebuild with clarendon 3Jan 05, 2014 2:51 pm Tetam Hi, we are doing a knockdown rebuild and have been told by another builder too that there are quite a few additional costs associated with this. So what you've said sounds correct to me based on my limited knowledge. How far into the building process are you? Hi, we are going for one more tender with another builder to compare the tender . if both tender will be same than we will sign the contract with Clarendon. Hopefully we will be in the position to final something at the end of this month. Re: Anyone knockdown/ rebuild with clarendon 4Jan 05, 2014 4:48 pm Get a breakdown of those figures. They can often hide allowances for stuff you don't require. "Council and other requirement" - what exactly are they charging you $13K for? You don't have to take it at face value and can ask them to sharpen their pencils. $3k for protection of overhead wires will be them hanging brightly coloured plastic strips on the wires to warn crane operators and deliveries. Site cost of $40k - what are they including? I found upon receiving a breakdown that there were unnecessary costs that could be struck out, and some that we were being charged twice for the same thing under different "requirement" provisional sums. Understand what they are charging you for and don't blindly sign off on it. Site costs at Clarendon might include different things in it than another builders site costs quote, and you'll need to make sure you compare apples with apples. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Re: Anyone knockdown/ rebuild with clarendon 5Jan 05, 2014 4:56 pm Hi Narrowblock, I'd be interested to hear the results of your other tender. Hope it goes well. When do you get the other tender? Bluesuede, thanks for the info about getting a breakdown. That's really helpful for us to know too. Re: Anyone knockdown/ rebuild with clarendon 6Jan 07, 2014 9:56 pm Bluesuede Get a breakdown of those figures. They can often hide allowances for stuff you don't require. "Council and other requirement" - what exactly are they charging you $13K for? You don't have to take it at face value and can ask them to sharpen their pencils. $3k for protection of overhead wires will be them hanging brightly coloured plastic strips on the wires to warn crane operators and deliveries. Site cost of $40k - what are they including? I found upon receiving a breakdown that there were unnecessary costs that could be struck out, and some that we were being charged twice for the same thing under different "requirement" provisional sums. Understand what they are charging you for and don't blindly sign off on it. Site costs at Clarendon might include different things in it than another builders site costs quote, and you'll need to make sure you compare apples with apples. Thanks Bluesuede for your reply. I am copying wriiting my sitecost incusions which is 40,000 and Provisional allowance : Additional survey cost due to existing dwelling Earthworks : provide a balanced cut and fill up tp 1.0 m to achieve a level building platform Provide 20Mpa concrete piering Provide H1 class slab Provide a concrete deep edge beam Provide scaffold to single storey due to additional heaight of drop edge beam Concrete pumps Cut and repair existing concrete footpath to front of property as require of run of services Provide sewer connection to junction at front within boundary Provide 100mm stormwater connection to easement via rainwater tank Water connection : near side to existing meter position Overhead Power -3 phase provision .Provide property pole,overhead power to pole and underground pole to house . Provide traffic control measures Due to site constraints ,provide site handling Provide shade cloth to scafoold to comply with occupational health and safety requirements Total : $40,000 Provisional Allowances Provisional allowance for power to propose knockdown site as required : $750 Provisional allowance for additional fill to achieve building platform :$5000 Provisional allowance for sewer connection to existing junction : $2000 Provisional allowance for stormwater to hydraulics engineer :$1500 Provisional allowance for render finish to facade : $5000 protection of overhead electrical wiring servicing adjacent property : $3,000 Due to above site constraint ,provide hoarding to scaffolds to comply with occupational Health and safety requirements :$3,000 provisional allowance for de-energizing of the power lines during scaffold install and dismantle ,subject to network operation requirement: $3,000 Total provisional allowance :32,250 so our site cost is 40k+32250=72,250 which looks too high . and now we are eagerly waiting for another tender so that we can decide something. Thanks, Arpita Re: Anyone knockdown/ rebuild with clarendon 7Jan 07, 2014 9:59 pm Tetam Hi Narrowblock, I'd be interested to hear the results of your other tender. Hope it goes well. When do you get the other tender? Bluesuede, thanks for the info about getting a breakdown. That's really helpful for us to know too. Hi Tetam, sure i will update you how it goes.finger cross Re: Anyone knockdown/ rebuild with clarendon 8Jan 08, 2014 10:08 am narrowblock Bluesuede Get a breakdown of those figures. They can often hide allowances for stuff you don't require. "Council and other requirement" - what exactly are they charging you $13K for? You don't have to take it at face value and can ask them to sharpen their pencils. $3k for protection of overhead wires will be them hanging brightly coloured plastic strips on the wires to warn crane operators and deliveries. Site cost of $40k - what are they including? I found upon receiving a breakdown that there were unnecessary costs that could be struck out, and some that we were being charged twice for the same thing under different "requirement" provisional sums. Understand what they are charging you for and don't blindly sign off on it. Site costs at Clarendon might include different things in it than another builders site costs quote, and you'll need to make sure you compare apples with apples. Thanks Bluesuede for your reply. I am copying wriiting my sitecost incusions which is 40,000 and Provisional allowance : Additional survey cost due to existing dwelling Earthworks : provide a balanced cut and fill up tp 1.0 m to achieve a level building platform Provide 20Mpa concrete piering Provide H1 class slab Provide a concrete deep edge beam Provide scaffold to single storey due to additional heaight of drop edge beam Concrete pumps Cut and repair existing concrete footpath to front of property as require of run of services Provide sewer connection to junction at front within boundary Provide 100mm stormwater connection to easement via rainwater tank Water connection : near side to existing meter position Overhead Power -3 phase provision .Provide property pole,overhead power to pole and underground pole to house . Provide traffic control measures Due to site constraints ,provide site handling Provide shade cloth to scafoold to comply with occupational health and safety requirements Total : $40,000 Provisional Allowances Provisional allowance for power to propose knockdown site as required : $750 Provisional allowance for additional fill to achieve building platform :$5000 Provisional allowance for sewer connection to existing junction : $2000 Provisional allowance for stormwater to hydraulics engineer :$1500 Provisional allowance for render finish to facade : $5000 protection of overhead electrical wiring servicing adjacent property : $3,000 Due to above site constraint ,provide hoarding to scaffolds to comply with occupational Health and safety requirements :$3,000 provisional allowance for de-energizing of the power lines during scaffold install and dismantle ,subject to network operation requirement: $3,000 Total provisional allowance :32,250 so our site cost is 40k+32250=72,250 which looks too high . and now we are eagerly waiting for another tender so that we can decide something. Thanks, Arpita Looking at that list, straight away I'd be asking why you're being charged twice for sewer connection and storm water connection. Does your black have any access issues other than overhead power lines? I'd query the site constraints:site handling charge. If its an existing site services should be provided to the block already so why would they need to cut and repair the footpath for provision of services? You might want to check with the council also with regards to requirements for hoarding on the scaffolds. If the scaffold is behind the property line with a decent set back and the site is fenced off, then why are hoardings required? Just a few thoughts Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere… 1 13686 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8578 multiple occ properties are always billed by trades at a premium, rarely per sqm for the lot. You either have trades you know whoe will do by sqm or youre going to get… 1 2250 |
