Browse Forums Building A New House Re: Fence conflict 2Nov 18, 2013 4:50 am Probably the key question is "Was your block built up at the boundary?" The following link provides some information on retaining wall fairness: http://www.anewhouse.com.au/2012/06/ret ... -fairness/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Fence conflict 3Nov 18, 2013 8:42 am How ever alters natural ground level should pay for retaining. If you were both level before cut and he cut down he pays. If you are both level and you fill up then you pay. http://www.betterthansheets.com.au - Why use sheets for curtains in your brand new home use Better Than Sheets Temporary Paper blinds instead! Re: Fence conflict 4Nov 18, 2013 10:28 am You can get colourbond retaining panels which may the answer here Steel Plinth Retaining This type of retaining fits directly under the bottom rail of your colourbond fence, its quite a thick heavy steel thats sealed, this sort of retaining is only good for 150mm to 300mm high, but is fantastic because no expensive walls have to be built on one side of the boundry because it goes directly under the fence, it’s cheaper than a wall definately but does not have the same strength but definately is good for retaining upto 300mm high Yes i guess this is one of the main reason as i checked one post foundation 4 9996 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7473 1 4581 |
