Browse Forums Building A New House Re: Stormwater drainage issue due to fall of land 3Nov 06, 2013 8:45 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater drainage issue due to fall of land 5Nov 06, 2013 12:43 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater drainage issue due to fall of land 6Nov 06, 2013 12:46 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Stormwater drainage issue due to fall of land 8Nov 06, 2013 11:07 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater drainage issue due to fall of land 9Nov 09, 2013 1:46 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater drainage issue due to fall of land 11Nov 11, 2013 8:49 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater drainage issue due to fall of land 12Nov 11, 2013 11:26 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 13 6661 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4716 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18434 |
