Browse Forums Building A New House Re: Piering inspection - Things you forgot 2Sep 21, 2013 10:29 pm Try and get a copy of the engineering drawings for your slab (or at least ask to see them when you attend the pier inspection). Those drawings will show the locations of piers and include specs for any boreholes and piers. As an example of pier specs, the engineering drawings for a house that was previously approved on my block had the following (this was associated with a design for the previous owner's builder): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Presumably the Principal Certifying Authority may also be in attendance when piers are bored. You could ask for a copy of their stage inspection report? Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11642 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98689 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5347 |
