Browse Forums Building A New House 1 Sep 11, 2013 12:48 pm Hi All, I am hoping that someone will be able to porvide me with some advice/opinions please... We will shortly commence building in the Bacchus Marsh area. We have found a floorplan that we like through a volume builder that we were originally going to make some small chanegs to. Our family circumstanes have recently changed as a result we are now looking to build a property that has dual residency. We have two options - build the volume builder house, and then add a granny flat to the back yard, or potentially go through a customer builder and build a similar floor plan to what we are after, but then incldue the granny flat under the roofline (so one house, with a small zone (kitchenette, loung & 2 bedrooms) and then the rest of the main house (if that makes sense..) Our preliminary investigations were that a standalone granny flat will be within the $100K budget we are hoping to do it within... Would anybody have any indication on how much more we could expect to pay for a custom builder - (eg: the price of the volume builder house was $220k through the volume builder - if i was to build the same house, plus the extra four rooms for the seperate living zone, is that likely to set me back more than the $100K extra....?) I know the only way to get an accurate price is to actaully speak with a volume builder, but i was interested to do some background work before hand to get an idea of the feasibility of going through a custom builder... Thanks in advance for any responses. Re: Volume builder vs custom builder 2Sep 11, 2013 1:40 pm In my limited experience and very vague terms; Volume Builder: $1,000 - $1,200 per m² Custom Builder: $1,300 - $2,000 per m² So your Volume Builder house $220k + Granny Flat $100k sounds like 290m² total. There are efficiencies in building as one home (say 10%), so I'd expect a 290m² home with a custom builder to cost you $350,000 minimum. Re: Volume builder vs custom builder 3Sep 11, 2013 2:33 pm I'm going to say that, based on what I've seen: Volume Builder: $1,000 - $2200 per sq.m Custom Builder: $1,300 - $SkysTheLimit per sq.m ie. there's a really big overlap. IMHO you really need to get it costed both ways, if planning on making a lot of modifications to a volume-builder design ... and depending on what you want in the residences. On something totally different; you've looked at the dual-occupancy regulations I assume? Obviously I'm in a totally different state, in a totally different council area & with a totally different block, but we couldn't build a dual-oc house/townhouse with two kitchens under the same roof yet we could build a house with separate granny-flat. Re: Volume builder vs custom builder 5Sep 11, 2013 8:27 pm I think if you want something other than basically what the volume builder offers, then go custom. Main reason we went custom was design reasons. People have also posted experience that volume builders price isn't what it seems once you add in the selections you actually want, such as fittings, flooring, number of power points per room etc. Re: Volume builder vs custom builder 6Nov 14, 2013 12:28 pm Hi did you decide on a builder we are in the same situation building in bacchus marsh. Trying to find a builder to do a custom design for not a ridiculous price. We were even thinking owner builder? Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25275 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18642 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110893 |
