Browse Forums Building A New House 1 Aug 29, 2013 1:42 pm Hi, I am looking to build a two story house on a battle axe block of land which is 20M by 26M depth. Most of the project houses are length wise. With CDC, need to have 8M from the back fence and 6M in front for turning circle leaves me only 12M depth for a house. The lot is South facing. Any one had come across some builders/design that would suit this block. Any suggestions would be appreciated. thanks Firsthome2 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 2Sep 07, 2013 12:41 am Where are you building? Do you really need CDC? You might be able to make more effective use of your block if you don't go down the CDC path (although I may be wrong on that). Developer / council approval for my build only took about 2 months. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: House design for 16MX12M building envelope? 3Sep 07, 2013 7:29 am The land is in Epping, comes under Hornsby council. Council will allow only 50% of the land, so would be about 260SM, where as CDC you could build up to 330SM. My understanding is that CDC is easier and quicker process to get the approval. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 4Sep 07, 2013 8:38 am This developer has lots of plans that would fit that envelope. Amazing what can be fitted into a tight space. Would give you plenty of ideas. http://www.summitprojects.com.au/development-plans/standard-development-plans/ Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: House design for 16MX12M building envelope? 5Sep 07, 2013 4:17 pm my building footprint is around 8m x 15m or thereabouts I think. Plans are on blog in my signature. We wanted a smallish house - just enough and efficient use of space. Re: House design for 16MX12M building envelope? 6Sep 07, 2013 7:55 pm Thanks, I would like it bit bigger than yours, I want to avoid big bathroom and hallways, but like bigger rooms and living areas. I have started the process with Kurmond, hope we could come up with a plan that fits the requirement and budget. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 7Sep 07, 2013 8:17 pm firsthome2 Thanks, I would like it bit bigger than yours, I want to avoid big bathroom and hallways, but like bigger rooms and living areas. I have started the process with Kurmond, hope we could come up with a plan that fits the requirement and budget. yeah I reckon you could easily pop out sideways by 2m and that would give you bedrooms 4 x 6 for master, 3 x 5 for seconds and increase living area huge. Pop out at garage by 2m and you get a double... but really - 16 x 12 is a massive envelope, plenty of options will fit on that. Our block is only 12.19m wide! Re: House design suggestions 8Oct 04, 2013 9:03 pm 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 9Oct 04, 2013 9:25 pm Finally managed to load the plan. this is for a battle-axe block 20X26M depth with driveway on the right. Any one with suggestions on this design, where should the garage be? 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 10Oct 04, 2013 9:42 pm I'd move the door to the Home Theatre to the back of the room. As you've got it, you would be walking in front of the screen. Unfortunately I couldn't do that for my build Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: House design suggestions 11Oct 05, 2013 8:45 pm Thanks maximus, excellent point. I am interested in the opinion of the layout. How to make the most of rear North. Being a battle-axe block, like to avoid just the garage is seen from the road, if possible. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: House design for 16MX12M building envelope? 12Sep 13, 2014 9:24 pm Hi firsthome2, thanks for your mail, haven't been on here for ages, are you still in the planning stages? The first thing I would do it to include a long, thin, horizontal window in the northern wall of the theatre room, if you're too far along to radically change the plan. I'm not so sure about moving the theatre room door to the back, ours is in the same position as yours and we have no problem. I think a door at the back would limit furniture placement (sofas and side tables). I wonder if you could move the house so it's on the western setback boundary, that way you might be able to have access to the back down the side of the garage, rather than through the back of it. This way you could regain your garage storage wall (great for hanging gardening tools) and maybe rejig the back of the house to put a room behind the garage and gain more windows on the northern side? From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5477 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13833 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19515 |
