Browse Forums Building A New House 1 Aug 28, 2013 5:58 pm Hi, We have moved in to our new Carlisle Indra 20. While the house itself has been great, with not too many issues and all minor, as a naive first home owner I've only just noticed that the outside solar hot water has been installed on a 10 inch high packed mound of dirt, not slab/concrete. My naive assumption is this is a disaster waiting to happen. If it is, can anyone advise remedial steps? I was planning on concreting around that area anyhow as its only a 1.5 gap down the side to the boundary fence. Is this something Carlisle should have sorted out and do we have any recourse with the warranty? Apologies if this is simple stuff Re: Hot water tank - installed on dirt mound - help! 2Aug 28, 2013 7:25 pm The australian standard for hot water units AS 3500 says the unit shall be installed (c) On a level, stable and impervious base— (i) of bonded brick or concrete cast in situ, having a thickness of not less than 75 mm; or (ii) of pre-cast concrete having a thickness of not less than 50 mm; and (iii) having the top of the base not less than 50 mm above the surrounding surface. Dirt don't count!! @builderforlife Building inspector and passionate about construction When you need an expert to take a look. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14074 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 |
