Browse Forums Building A New House Re: Did you upgrade your internal doors?? Why is it so hard? 2Aug 28, 2013 10:57 am Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: Did you upgrade your internal doors?? Why is it so hard? 4Aug 28, 2013 11:33 am ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Did you upgrade your internal doors?? Why is it so hard? 5Sep 03, 2013 2:21 pm Build thread: viewtopic.php?f=31&t=65085 Re: Did you upgrade your internal doors?? Why is it so hard? 6Sep 03, 2013 3:37 pm ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Did you upgrade internal doors?? Advice on honeycomb/sol 7Sep 03, 2013 6:29 pm We upgraded all our internal doors for exactly the same reason. We wanted a quiet house, and put sound batts in all internal walls, so without changing internal doors to solid core, this would have reduced effectiveness of the sound batts. We left wardrobe doors as standard (honeycomb) but all other internals doors were upgraded to solid. We did not bother with wardrobe doors because these are inside bedrooms and the contents of the wardrobe provides additional sound insulation between rooms. (We have hinged doors to all wardrobes because I hate sliding wardrobe doors.) Our builder used Corinthian also, however I believe they now use Hume. Our door profile is flush in keeping with our modern style, which may have kept upgrade cost down compared to solid panel doors, however to upgrade 14 doors to solid was $1,806. Corinthians name for solid doors is 'Solidor'. They do reduce sound, even on sliding doors which we have to laundry and butlers' pantry. And as PAB_34 has said, the solid doors have a nice feel to them when you open and close them due to the extra weight. Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3277 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 |
