Browse Forums Building A New House 1 May 04, 2008 9:35 pm Ihave asked this before but did not get many replies
can somebody tell me if water siting on our tonge and groove wood floors subjected to the rain will make problems,we are having wood floors laid on top of this after handover...........i am not sure when ashford will put on roof and i am a bit worried. braveheart Re: rain and floors 2May 04, 2008 9:58 pm It was also brought up some time ago on the following link
https://forum.homeone.com.au/viewtopic.p ... highlight= I thought I'd also seen a response to a similar question more recently.....still hunting. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: rain and floors 3May 06, 2008 6:49 pm I think that's happened to most of us lately....well, in Sydney anyway. I tried not to think about it too much as the rain pelted down and down there's not much you can do about it really. Built a Clarendon 'Balmain' 2008 Re: rain and floors 4May 06, 2008 6:59 pm If you’re talking about your slab getting wet, by the time they are finished your home you shouldn’t have a problem, by the way, there is an underlay that goes down under the timber flooring that protects from the moister through the slab!
It’s after it’s laid….that you need to be careful of water damage. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: rain and floors 5May 06, 2008 10:05 pm We finally got a roof on ours after a lot of rain that pooled on the yellow tongue floor. So far, it doesn't look too bad, but will clearly need a bit of sanding back at the edges. Some parts of the floor had pools of water sitting on them for a week (guess the floor is level, at least!!), and look OK, except where something heavy has been dropped and punched a hole through (my money is on the scaffolding...) I guess God didn't use subbies... Re: rain and floors 6May 12, 2008 1:45 pm we got very bad floor lipping problem due to floor board exposed in rains during the long 6 weeks brick work period. our builder did floor sanding twice (extra one because we complaints) but still can't get it to a very level condition and this impacts our timber flooring work. Our timber floor guy tried to help but there's a limit on how much you can cut off from the floor board joining area. Now after all timber floor work finished, in a few area we can still feel the timber floor not level...
I guess unless your builder do the roof before the brick work, you can't avoid the problem of exposing your 1st floor floor boards in rain. May be you can request to have it temporarily covered by some plastic stuffs?? Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3436 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3521 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 |
