Browse Forums Windows & Doors 1 Aug 13, 2013 9:57 pm Hi all We are looking in to the cost of double glazing, smart glass etc. What is everyone choosing and what made you choose it? Re: Low E glass - are you using it, pros and cons 2Aug 14, 2013 9:31 am If you are in NSW, BASIX will have the biggest influence over which type of glass you will have to use especially for your N, E & W windows ( depending on your existing and proposed shade treatments for those windows too ). Low-e glass and an improved aluminium frame would probably be the most common window combo these days. You may get more replies if you post this question in the Window & Doors section. viewforum.php?f=23 Stewie Re: Low E glass - are you using it, pros and cons 3Aug 16, 2013 8:52 pm Thank you! I didn't even realise there was a dedicated area. Thanks for your reply Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12035 0 2019 4 6201 |
