Browse Forums Windows & Doors 1 Aug 13, 2013 9:23 pm Hi guys, just wanted to get some ideas, should I put the standard timber door frame for laundry and garage back door? or should I put aluminum door frames? is there any advantage of getting aluminum? eg. laundry might be high in moisture and could damage timber frame? is that possible? which one is more expensive? I am going for timber frame for main entrance by the way because I am getting timber entrance door so it matches. just not sure about laundry and garage... Re: Laundry and Garage back door, timber frame or aluminium? 2Aug 14, 2013 6:16 am we have aluminum sliding doors in both garage and laundry and front door timber. in old house the moisture did get to the timber door in the laundry Re: Laundry and Garage back door, timber frame or aluminium? 3Aug 14, 2013 7:47 am melbbuild Hi guys, just wanted to get some ideas, should I put the standard timber door frame for laundry and garage back door? or should I put aluminum door frames? is there any advantage of getting aluminum? eg. laundry might be high in moisture and could damage timber frame? is that possible? which one is more expensive? I am going for timber frame for main entrance by the way because I am getting timber entrance door so it matches. just not sure about laundry and garage... Aluminium will be more expensive for a simple door frame. It's quite common to use a 1450 wide aluminium sliding door in the laundry these days. If the timber is well maintained you should not have a problem. An aluminium door can be used in the garage if the wall is brick veneer, but it is unsuitable for a single skin brick. Aluminium never needs painting. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is 100% true. You can not hang anything on steel frames. very frustrating 8 4166 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7631 Move your linen into laundry and access laundry from your present linen space 1 7978 |
