Waffle pod slabs
We had to have double glazed windows to the east/west walls and upgraded insulation. This added extra along with the increased slab cost.
So if you site is straight forward enough I believe you can add a waffle pod with great confidence. However there's still plenty of applications where raft is required. As we found out.
The whole styro block thing affects thermal mass in a good way I believe.
With respect to "them" not passing the savings on; well, theoretically the market & competition takes care of that. Everyone uses waffle-pods, and everyone competes with each other. If you want to use anything unusual for a slab, you'll pay more.
Am also wondering about the fact that foam is flexible.
Shouldn't matter, it's only filling space (maybe it gets used for an hour or two to hold the wet concrete in place while it dries?). It doesn't have any structural purpose.
Quote:
Also I'd be curious as I use to be a volunteer fire fighter how safe this would be in a fire. As I know that in fires concrete that has air pockets tends to explode due to the heated air expanding
You may have a point there; but don't forget it's under the heat & under a layer of concrete. Having said that, it'd also be a bit odd if it's never been considered with respect to the BAL-x requirements for bushfire-prone areas.
Hi just wanted some info on these slabs. They concern me a bit but hey I'm no engineer. I can see how the foam won't break down or could even be that strong compared to a conventional style of slab. To me it just seems like a cheaper way to construct a foundation. Rather then a better way. And yet they don't pass the cost savings on. Any way just wondering people's thoughts
My parents built two houses in the 90's. Both had waffle-slab construction. This type of slab has been in use for years.
2
The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement…
6/02/2024
9
my suspicion - some builders, they do usually make 'odd' settings in their site plan / pricing as their standards - being hopeful that first - the initial price is…
