Browse Forums Building A New House Re: Concrete Apron on Angled Slope 6Jul 24, 2013 2:45 pm Can you throw up your siteplan? May be easier to put all the pieces together! You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11203 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223942 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24923 |
