Browse Forums Building A New House 1 Jul 17, 2013 11:36 am Does anyone know details about this rebate? I am currently building my new home in SA. According to the "building rules regarding rainwater tanks", I have to install a minimum 1000L water tank and plumb to a toilet before occupied. My question is: 1. Is this rebate open to new home building? 2. what does it means "stand alone" water tank? 3. I have to plumb the water tank into a toilet. Does I still qualify for the rebate? 4. "UP to $200"? How does SA water calculate the rebate money? I have already sent a enquiry to SA water. Before I get any feedback, I want to see whether someone knows that. I will update the SA water reply as soon as I get it. Thanks Re: [SA] Rainwater Tank Rebate $200? 3Jul 17, 2013 12:36 pm Here is some further info http://www.sawater.com.au/sawater/yourh ... rtanks.htm Rainwater Tank Rebate Collect water and up to $200. You can apply for up to $200 for a new stand alone rainwater tank with a capacity of 1000 litres or more which is not connected to household plumbing.
The receipt of purchase must be an original. The tank must have a minimum capacity of 1000 litres. Only one stand alone tank rebate is available per property. There is no requirement for the rainwater tank to be connected to household plumbing. To check if you qualify for the rebate, please read the full terms and conditions (including purchase date eligibility) which are available on the application form (in PDF format): http://www.sawater.com.au/NR/rdonlyres/ ... ankapp.pdf Re: [SA] Rainwater Tank Rebate $200? 4Jul 17, 2013 12:37 pm oh, SA water reply me so quick. 1. yes 2. "stand alone" means that only connect to stormwater pipes, 3. yes 4. if you spent less than $200, your rebate is the amount paid for the tank. If more than $200, your rebate is maximum $200. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31453 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31289 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19723 |
