Browse Forums Building A New House 1 Jul 17, 2013 11:34 am Hello all, Trying to get some advice here... I have seen lots in the forums about people filling up their houses with batten fix lights and having them switched to LED post handover... sounds like a plan at $42 vs $210... but what I want to know is if it is possible to place just one of the batten lights in each room and then have the sparky wire for all 4 LED's from there... can that be done or should I just place all the battens now eliminating the amount of work for the sparky at the end (i.e just switching the fittings rather than also having to run cable etc.) Am I asking a how long is a piece of string type question? Probably! Thanks in advance wise homeone forum readers Colours - 6/13 Tender & Contract - 7/13 Title - 12/5/14 Scrape - 29/5/14 Frame complete - 20/6/14 Re: Changing batten to LED post handover (1 batten to 4 LED) 2Jul 17, 2013 12:55 pm Is your house single or double storey??? If it is single you can do basically what you want. An electrician can get into the roof space and install the downlights after handover. If you are having a double storey house you need a batten holder for every place you want a downlight. Modified Fernside 38 Rawson Homes Blog: http://www.thehousethatmatandjenbuilt.blogspot.com Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=60501 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11933 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5540 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 4245 |
