Browse Forums Windows & Doors 1 Jul 17, 2013 11:02 am I am aware that both window company and door company provides door frames. Which one should we choose? I think window company's door frame tends to match with your window frames so it is consistent on the facacde. where as door company frame is to match the door... Re: Entrance door frames 2Jul 24, 2013 12:55 pm HI Melbbuild In my experience the window company will supply the door frames with the windows. This is the best option as the frames will then match the profile / style of the windows. The door frames will be made to suit standard door sizes etc - so i would always get the door frames with the windows. Most window companies will be able to assist you. See link for bowens windows http://www.bowens.com.au/trade/tradeSer ... s-services Hope this helps you The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7738 |
