Browse Forums Building A New House 1 Jul 14, 2013 10:59 pm Seems as though the standard price for a flat metal roof brick double garage attached to dwelling is $40K
Seems as though the builders margin is over 50% to me Thus thinking of owner building slab ( with concreter/excavator )-> $5000 ... bricks (qty 3000, with bricklayer) -> $9000 ... roof -> $1500 ( have it already elsewhere, self mount )... Plans permits soil -> $2000.. doors ( 1 large , 1 small, self mounted) -> $2000 Any comments? JB1 - Thanks very much for all that.. By doors I meant garage doors. roof plumber.. well I am actually replacing a carport and planning to use that for run-off Re: Brick garage 2Jul 15, 2013 12:49 am I'm not sure you will be able to reuse your existing roof. I would owner build, it's rather simple. Brick work you will be able to get a bit cheaper. A carpenter will be able to assist with mounting the roof structure. You forgot the cost of a roofing plumber and plumber for your drainage. You will also need a lintel and garage door or 2. Add a window too. Plus electrician. Again I can't see how you can reuse the existing roof as just roofing plumbers can't be bothered trying to reuse secondhand material. Too much effort for them, assuming your engineer specifies your existing roof design. DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 8729 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9593 |
