Browse Forums Building A New House 1 Jul 08, 2013 7:35 pm Hi, I am considering to buy a new land at woodcroft, adelaide SA. I have noticed a sewer and drainage easement on the left side of my property which is partially on the front as well. As I am buying a land for the first time and will build a house through fairmont homes as a home and land pacakage, I need to know should I consider this drainage easement ? Would it devalues the property and would it be hard to resale it ? What would happen if in case the easement stops working or having issues in future? http://www.realtysa.com.au/land-for-sale/horizon-woodcroft ( Horizon - Apollo - Stage 1 - Sales and building envelope plan ) [img]C:\Users\HarshNeha\Desktop\horizon_sales_plan.pdf[/img] Above Link to see the map, The block is number 14 on the left side at Arkle Place. Thanks and Regards, Harry Re: sewer and drainage easement 3Jul 08, 2013 8:44 pm From looking at the plan I wouldn't be worrying about the easement. Its fairly small and shouldn't affect what you want to build on the block. An easement is only giving someone else the right to run their pipes under your property. About 30-40% of all properties have an easement so its unlikely to affect future sales. If the pipes under the easement gat blocked its up to the sewerage, or drainage authority to fix.....Not you. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: sewer and drainage easement 4Jul 08, 2013 9:00 pm Thanks for your reply, I have been to the block for inspection and found out that sewer drianage is right in the front of the block. So I was wondering what if after building the house if in case it requires any maintenance then it will be a much hassle for us for parking and also it would not look good right at the house front. Do you know whether there will be a manhole on it or how would it look ? Can you please suggest whether this block is worth buying as I am a first home buyer and have absolutely no idea what I am doing. Thanks !! Re: sewer and drainage easement 5Jul 09, 2013 7:53 pm As far as the easement is concerned it wouldn't affect my decision to purchase. Even if there is a manhole there most manholes wouldn't get lifted once in every 5 years for an hour so it isn't going to be much of a nuisance at all. I see plenty of houses with manholes in the middle of the driveway and even next to the back door. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: sewer and drainage easement 6Jul 09, 2013 8:34 pm Thank you very much for the information, Sir. Much appreciate it. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17154 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16145 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3357 |
