Browse Forums Building A New House 1 Jun 19, 2013 4:24 pm Hi all, we've decided to build our first dream home but need some assistance. I've attached a copy of plan on our land. Our land is lot 22 (in red) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1. Is it correct that our back yard is facing North? 2. I understand that we can only build a home 60% of the land total area. Given our block of land is nearly 420m2. Does that mean we can build a 250m2 (27 sqm) home? We've thought that if we can't build more than 25sqm home, we're not going to build. That's why we haven't talked to any other draftman yet. Thanks for your help. Re: Please help with copy of plan 2Jun 19, 2013 4:40 pm Hi there, 1. yep your backyard is facing north 2. I'm not sure if the 60% rule is applicable everywhere. but for Wyndham council (Melbourne west area) , it is 60% max. Note that 60% usually means your roof line. so you can hard pave/concrete more than 60% as long as the roof line is max 60%. Hope this helps. Re: Please help with copy of plan 3Jun 19, 2013 4:48 pm Also, not sure if it applies to all councils but here in WA the alfresco area is not considered, so you only need to consider living area, garage and porch/portico. Re: Please help with copy of plan 4Jun 19, 2013 4:53 pm Land use percentage refers to the footprint on the land. No reason not to do a double storey house on the land to get more space in your house. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Re: Please help with copy of plan 5Jun 19, 2013 5:00 pm Thanks for your quick reponses. Forgot to mention that we only want a single storey house (cheaper to build and less maintenance). Our land is in inner west of Melbourne (Maribyrnong council) and in an established area. Re: Please help with copy of plan 6Jun 19, 2013 5:45 pm Bluesuede Land use percentage refers to the footprint on the land. No reason not to do a double storey house on the land to get more space in your house. There may be different wordings of different rules, so this may not be correct depending on the exact rules in Maribyrnong. 60% sounds more like a floorspace-ratio than a "footprint" to me, although being a smaller block in an inner suburb the rules probably do allow you to cover more of the land. Our council (and NSW CDC) regulations don't allow a floorspace-ratio higher than 50%; but you don't need to count any outdoor areas at ground-level nor voids. However, we've got a different rule & different calculation for footprint (which does include alfrescos etc). Re: Please help with copy of plan 7Jun 19, 2013 5:54 pm Maribynong council says maximum of 60% covered by Building( unless the Planning zone specifies a different figure) see http://planningschemes.dpcd.vic.gov.au/ ... /home.html for the general planning scheme and http://planningschemes.dpcd.vic.gov.au/aavpp/54_03.pdf for the clauses on setbacks and site coverage. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Please help with copy of plan 8Jun 19, 2013 6:21 pm newstart2day Thanks for your quick reponses. Forgot to mention that we only want a single storey house (cheaper to build and less maintenance). Our land is in inner west of Melbourne (Maribyrnong council) and in an established area. Maribyrnong? Oh... good luck. You've got all sorts of challenges there with design guidelines, heritage restrictions, neighbourhood character requirements... I suggest you go to their town planning site and read through all their requirements... and engage an architect to design it and ensure it meets all the criteria and coordinate the process. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11228 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17260 5 10459 |
