Browse Forums Building A New House 1 Jun 14, 2013 2:03 pm I'm pretty sure an antenna isn't part of our package, so who do I go through? Is it our electrician? It's probably easier to organise during the install as scaffolding will still be up, but I'm not sure if M3tric0n will allow a private contractor on site. An option to install an antenna was never actually offered to us, just the internal points. Re: 2 storey builds - who installed your antenna and when? 2Jun 14, 2013 2:16 pm I believe you can do this after the handover. Pro Antenna installers are your best bet. They will have all the tools required for checking signal strength and installing amp if required etc. We are currently at this stage and I am getting some quotes through service central. Re: 2 storey builds - who installed your antenna and when? 4Jun 14, 2013 5:46 pm Check with your electrician as to the internal wiring done. Much easier obviously to have all wiring/cabling done during building. Our antenna is included in our electrical pricing. Re: 2 storey builds - who installed your antenna and when? 5Jun 14, 2013 8:35 pm Ours was an extra arranged through the builder's electrician, costing an additional $450 Hi, We are looking for a builder that can build a small home (smaller length) on a sloping site. We came across Mojo's Zephyr design 10.6 m wide and 11.5 m length. Does… 0 23017 DIY, Home Maintenance & Repair Brilliant - thanks so much for that. I didn't want to start pulling too hard on it if there was some other way it was attached, but yep, it was just the paint sticking it… 2 3170 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 |
