tiles - ceramic v porcelain etc
can anyone give me advise as im now trying to select my tiles
ive been told to go porcelain because they are stronger, but then ive read that polished porcelain tiles are bad.
can anyone shed some light on this?
We have chosen sealed, semi-polished porcelain tiles for our build. They're not high shine/glossy so they won't look dirty as quick and because they're sealed they're much less porous so they're easier to clean.
However, even though you can get rectified porcelain rather cheap these days - don't forget they will cost an extra $30ish a meter to lay.
wow.
has anyone had any issues with the optical hazing on porcelain tiles? is it just on the polished porcelain or on all porcelain?
I could image it would take say an extra 5 to 10 minutes per metre. That is a massive hourly rate! For a skilled tiler it would hardly be much longer at all would it?
Our tiler quoted an extra $14/sqm for rectified porcelain tiles, mainly covering the cost of the wedges to hold the tiles level, and the extra time needed to get a perfectly even join and level height for the tiles.
Basically, the extra money is paying for the tiler to be more careful and to avoid imperfections, along with the tools needed to do so. That's not a bad thing at all.
we were going to go 600x600 but then thought it would look weird with only 1 and a half tiles width in the hallway
3
Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the…
19/07/2023
Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most…
17/08/2023
1
Hi Yash, Have you made a decision yet?
