Hi,
This facade https://picasaweb.google.com/101864544019738694615/January222013?authkey=Gv1sRgCKrDx7q4wP7ZQw#5836064279731385426 Has 200% colorbond dune render and 200% colourbond dune cladding.
But why do they look different?
Thanks,
Browse Forums Building A New House 1 Jun 05, 2013 11:37 pm Hi, This facade https://picasaweb.google.com/101864544019738694615/January222013?authkey=Gv1sRgCKrDx7q4wP7ZQw#5836064279731385426 Has 200% colorbond dune render and 200% colourbond dune cladding. But why do they look different? Thanks, Re: Different shades of dune 2Jun 06, 2013 10:41 am dune is a trademark colour of Colorbond owned by bluescope. The colour on steel is dune. when it comes to paint and render, it can be quite hard for companies to match the colour. It may be possible that the render tried to colour match without actually using dune however even if the correct dune render colour was used, the end colour can be affected by the application (thickness/method of application). It is nearly impossible for a powdercoated colour on steel to match a render or paint colour. Diferrent surfaces reflect light differently and this is the case in 99% of homes if you look closely enough. That said, the picture you linked to is a fairly big difference but that fact that the photo was taken in the shade, not sunlight can highlight the difference, it will be less noticable in the sunlight. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5235 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6347 |
