Browse Forums Building A New House 1 Jun 02, 2013 6:37 pm So I noticed a few days back that our mixer for the bathtub was directly right behind the tap and notified our BS right away. He said he we would contact the plumber and also look into it. Bought up the issue with him again during our onsite meeting the other day and said the plumber said it should be fine and there shouldn't be any issues, it is as "off the plan" anyway. Now that the tap and mixer has been installed (well kinda), just looking at it doesn't seem right and doesn't seem very practical. Well, that's what I believe to think.
Bring it up with the BS again? What does everyone else think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The person that did the drawings for this display home was smart enough to move it to the side.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Surely this should be fixed? 2Jun 02, 2013 6:40 pm personally if it was mine i would have it in the same spot, but higher than the spout. Re: Surely this should be fixed? 3Jun 02, 2013 9:56 pm From one of your photos it looks like you won't be able to open your tap from the middle position. I wouldn't accept that as its going to be a hassle. It should be off to one side, preferably the side nearest the entry position to the bath so you can run it easily without being inside the bath. Your bath looks great by the way! Can I ask what it is? (I am still in planning stage of building and after ideas) Re: Surely this should be fixed? 4Jun 02, 2013 10:12 pm It's a bad job and needs to be fixed. Nor quite as bad as this (http://www.anewhouse.com.au/?p=3797) but almost SORRY FOR THE BAD LINK-NOW FIXED Brian Probably neatest fix is to change the spout for a lower one The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Surely this should be fixed? 5Jun 12, 2013 7:02 pm Mrs Brown Bear From one of your photos it looks like you won't be able to open your tap from the middle position. I wouldn't accept that as its going to be a hassle. It should be off to one side, preferably the side nearest the entry position to the bath so you can run it easily without being inside the bath. Your bath looks great by the way! Can I ask what it is? (I am still in planning stage of building and after ideas) bashworth It's a bad job and needs to be fixed. Thanks everyone for your input! Looks the supervisor has agreed to fix it after some arguing though. He said that the tap could be altered so that it could somehow work and the fact that it's part of the "contract drawings" - I wasn't happy and told him it was obviously a stuff up on their end! So all is good, it's going to be moved "100mm" to the left next week! As for the bath Mr Brown Bear - I tried checking our colour selection documents/contracts and couldn't find anything on it, sorry! Re: Surely this should be fixed? 6Jun 13, 2013 2:45 pm Mrs Brown Bear Your bath looks great by the way! Can I ask what it is? (I am still in planning stage of building and after ideas) The bath looks like the Decina Uno - http://decina.com.au/our-products/bath- ... val-baths/ This is (or was) the standard bath for Prestige and Access house. Not sure if any changes to bath types. In most of the PD display homes. Re: Surely this should be fixed? 7Jun 13, 2013 2:48 pm tai27 Thanks everyone for your input! Looks the supervisor has agreed to fix it after some arguing though. He said that the tap could be altered so that it could somehow work and the fact that it's part of the "contract drawings" - I wasn't happy and told him it was obviously a stuff up on their end! So all is good, it's going to be moved "100mm" to the left next week! Great result. I just went to check my contract drawings. Agree that it is their stuff up as they are the ones that draw them. It annoys me that we are supposed to be the experts at reading every tiny detail on a plan that we are presented, then cross check, double check and triple check for this small details. Re: Surely this should be fixed? 8Jun 13, 2013 2:57 pm we have almost the same setup but the swivel spout is in the corner and the mixer is central to the end of the bath. this way you can lean your head back over the edge of the bath. Depends how you are going to use it but another option Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 18507 So AFAIk the outcomes of the BAL ratings form part of a clause that allows them to pass these costs on to you. However the more relevant detail is how did it go from 19… 1 10412 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 710 |
