Browse Forums Building A New House 1 Jun 02, 2013 1:30 pm Hi
We are thinking of putting bamboo flooring in our living area which include kitchen. We are building in South Australia on canal. Our really only option is to buy from Choice Flooring. The choices that we have is ARC and Arrow Sun. Both appear to be of the same quality. They are both cold pressed, strand woven bamboo flooring. However I am not sure whether to go cold pressed or hot pressed. Hot pressed seemed to work better in humidity environment than cold press. They are better for moisture. But where we are located we don't have problem with humidity. They are so many different arguments. Please my question is if you have bamboo flooring at home, has it been good? Any problem with it? Is there issue with maintenance? what is your option on it? Should I go for hot or cold pressed? any suggestion on brands? The color that we like is Champagne. I look forward to some feedback paula Re: BAMBOO FLOORING 2Jun 02, 2013 6:52 pm Look forward to hearing people's experiences as we are considering bamboo flooring Building in Myalup with Redink PCQ : Nov 2012 Prestart: 17 th March 2013 Builders Permit: Sept 2013 Completed build Aug 2014 viewtopic.php?f=31&t=67559 Re: BAMBOO FLOORING 3Jun 02, 2013 8:27 pm You will probably get a few more replies if you post this in the flooring section viewforum.php?f=7 Stewie 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6447 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16262 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6750 |
