Browse Forums Building A New House 1 May 27, 2013 9:25 pm Anyone had experience with having to put articulation (step ins / outs) on the side of their house for council requirements? We are looking at building a 2 storey in Caddens in Penrith, and have been advised that we may need a "cut in" / "step in" on the side of our house as it is a 2 storey wall that is 16.5m long. Can articulation be achieved by different building materials? The suggestion from our builder is to put a cut in into our living room, in the middle of the house, however this is not aesthetically pleasing. Can we argue at council that as our block is 45m long, a 16.5m wall is not that much in proportion? Any advice would be great! Re: Articulation on side of house 2May 27, 2013 11:02 pm Maybe have a look at similar builds in your suburb. This will give a good indication of what is required. Are you in a new estate? Many newer estates have quite specific building and siting requirements that can't be ignored. In my case there are approx 20 pages of requirements that need to be complied with. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Articulation on side of house 3May 28, 2013 6:45 am Brand new estate, so there is only 3 other houses there - all under construction. The development design guidelines don't apply to our release. So it really is just the council requirements / CDC requirements. Re: Articulation on side of house 4May 28, 2013 8:02 am Are you sure CDC requires it; and that it's not a council thing? You can find CDC requirements online, it's fairly easy to get a hold of. We were told something about articulation along the front of our house, but pretty much every design already looks like that so we were never affected ... however I don't remember reading it in the CDC guidelines. Re: Articulation on side of house 5May 30, 2013 9:28 pm definitely a council thing. I meant that we either need to comply with the basic council requirements, or CDC. We have decided to go CDC as it does not require the side articulation. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12290 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4683 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9245 |
