Browse Forums Building A New House 1 May 21, 2013 8:02 pm Hey guys I am building with H3nl3y and was wondering if anyone has done the following. 1. I want to add a slab extension for my air conditioner as otherwise they bolt it to the wall. The initial feedback from the administrator is that this cannot be done, however when I pointed out there is already a 700x700 extension added for the hot water service she said she would look into it. 2. Brivis add on cooling, has anyone added 2 units one for upstair and one for downstairs, or extra zone motors? I cant seem to get any answer on this!! Also is anyone else's administrator useless? Re: Slab extension 2May 21, 2013 9:40 pm You shouldn't need a slab extension. Just a small independent slab should do. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8471 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5457 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 |
