Browse Forums Building A New House Re: Building with Aveling in Byford - more waiting 144Sep 26, 2013 10:07 pm My Build viewtopic.php?f=31&t=64881 Re: Building with Aveling in Byford - more waiting 146Sep 26, 2013 11:04 pm My Thread: viewtopic.php?f=31&t=62001 Re: Building with Aveling in Byford - more waiting 147Sep 27, 2013 1:23 am My Build viewtopic.php?f=31&t=64881 Re: Building with Aveling in Byford - more waiting 150Sep 27, 2013 7:05 pm My Build viewtopic.php?f=31&t=64881 Re: Building with Aveling in Byford - moving to construction 152Sep 28, 2013 11:53 am My Thread: viewtopic.php?f=31&t=62001 Re: Building with Aveling in Byford - moving to construction 154Sep 28, 2013 1:36 pm My build thread: viewtopic.php?f=31&t=64437 Re: Building with Aveling in Byford - moving to construction 155Oct 03, 2013 10:56 pm My Build viewtopic.php?f=31&t=64881 Re: Building with Aveling in Byford - moving to construction 158Oct 06, 2013 10:34 pm So I was looking at 3Munkeys and Leanne's full height overheads which look great, and got me looking at my kitchen plans (again!). We have a bulkhead above our kitchen cupboards. Doing the math, it looks like the bulkhead will be about 30cm and that seems a little big to me. But it doesn't look too bad in the plans. Upon discussion with the other half we need to decide whether to go full height overheads, reduce the bulkhead or leave it as is. Please help!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build viewtopic.php?f=31&t=64881 Re: Building with Aveling in Byford - moving to construction 159Oct 06, 2013 10:38 pm The display version of the Le Mans had bulkhead over the overheads and they looked short/stumpy to me specially as in my current house we have them to the ceiling. I'm bit bias obviously but I say full height. New house we also opted for no cornices above cabinets I also noticed your space between bench top and oven heads is 60cm. Mine is 70cm in kitchen but 60cm in scullery & laundry. If that helps at all Re: Building with Aveling in Byford - moving to construction 160Oct 06, 2013 10:56 pm LeanneR I also noticed your space between bench top and oven heads is 60cm. Mine is 70cm in kitchen but 60cm in scullery & laundry Pretty sure you mean overheads? then yes, it is smaller as I had our benchtops raised to 1m. They reduced the window/splashback area to accomodate this. Is 70cm normal? Perhaps I could ask them to move the overheads upwards then. My Build viewtopic.php?f=31&t=64881 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5478 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19517 Although I am a big opponent of using waffle pod slabs over H2/P soils under any circumstances, in your case I would certainly opt in to keep piers under central… 1 2426 |
